Lenovo Yoga 710-15ISK RAM Replacement
    1. Lenovo Yoga 710-15ISK RAM Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 710-15ISK RAM Replacement, Back Cover: step 1, image 2 of 2
      • Flip your laptop over so the bottom is facing upwards.
      • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
      Ask FixBot
    2. Lenovo Yoga 710-15ISK RAM Replacement: step 2, image 1 of 1
      • Gently remove the back cover of the laptop with your fingers.
      Ask FixBot
    1. Lenovo Yoga 710-15ISK RAM Replacement, RAM: step 3, image 1 of 2 Lenovo Yoga 710-15ISK RAM Replacement, RAM: step 3, image 2 of 2
      • Use the spudger to detach the clips holding the RAM cover.
      • Gently pry the RAM cover up off of the motherboard using the spudger.
      Ask FixBot
    2. Lenovo Yoga 710-15ISK RAM Replacement: step 4, image 1 of 3 Lenovo Yoga 710-15ISK RAM Replacement: step 4, image 2 of 3 Lenovo Yoga 710-15ISK RAM Replacement: step 4, image 3 of 3
      • Use your fingers to take apart the clips holding the RAM in place.
      • Carefully slide the RAM out of its slot.
      Ask FixBot
Congratulations! You’ve successfully replaced the RAM in your Lenovo Yoga 710-15ISK. Enjoy the enhanced performance, whether for multitasking or demanding applications. If you encounter issues, refer to your laptop’s manual or seek professional assistance.
Elisa Normand
423 Reputation
4 Guides authored
UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G5
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 35
All Time: 907
