Lenovo Yoga 710-15IKB Fan Replacement
    1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: step 1, image 1 of 1
      • Ensure your computer is completely OFF before starting this guide.
      • Remove the ten 3.3 mm T5 screws from the base cover.
      • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
      Ask FixBot
    2. Lenovo Yoga 710-15IKB Fan  Replacement: step 2, image 1 of 1
      • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
      Ask FixBot
    3. Lenovo Yoga 710-15IKB Fan  Replacement: step 3, image 1 of 1
      • Lift and remove the back cover.
      Ask FixBot
    4. Lenovo Yoga 710-15IKB Fan  Replacement: step 4, image 1 of 1
      • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
      Ask FixBot
    5. Lenovo Yoga 710-15IKB Fan  Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
      Ask FixBot
    6. Lenovo Yoga 710-15IKB Fan  Replacement: step 6, image 1 of 1
      • Gently lift and remove the battery.
      Ask FixBot
    1. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: step 7, image 1 of 1
      Buy
      • Use tweezers to grab the fan harness.
      • Gently pull the harness to disconnect from motherboard.
      Ask FixBot
    2. Lenovo Yoga 710-15IKB Fan  Replacement: step 8, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
      Ask FixBot
Stephanie Alexander
757 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 41
All Time: 2,599
