Lenovo Yoga 3 Pro USB Ports Replacement
  1. Lenovo Yoga 3 Pro USB Ports Replacement, Battery: step 1, image 1 of 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
    Ask FixBot
  2. Lenovo Yoga 3 Pro USB Ports Replacement: step 2, image 1 of 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
    Ask FixBot
  3. Lenovo Yoga 3 Pro USB Ports Replacement: step 3, image 1 of 1
    • Remove the panel and place it in a safe location.
    Ask FixBot
  4. Lenovo Yoga 3 Pro USB Ports Replacement: step 4, image 1 of 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
    Ask FixBot
  5. Lenovo Yoga 3 Pro USB Ports Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
    Ask FixBot
  6. Lenovo Yoga 3 Pro USB Ports Replacement: step 6, image 1 of 1
    • Carefully lift and remove the battery.
    Ask FixBot
  7. Lenovo Yoga 3 Pro USB Ports Replacement, Speakers: step 7, image 1 of 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
    Ask FixBot
  8. Lenovo Yoga 3 Pro USB Ports Replacement: step 8, image 1 of 2 Lenovo Yoga 3 Pro USB Ports Replacement: step 8, image 2 of 2
    • Using the plastic opening tool, flip open tab as shown.
    Ask FixBot
  9. Lenovo Yoga 3 Pro USB Ports Replacement: step 9, image 1 of 3 Lenovo Yoga 3 Pro USB Ports Replacement: step 9, image 2 of 3 Lenovo Yoga 3 Pro USB Ports Replacement: step 9, image 3 of 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
    Ask FixBot
  10. Lenovo Yoga 3 Pro USB Ports Replacement: step 10, image 1 of 2 Lenovo Yoga 3 Pro USB Ports Replacement: step 10, image 2 of 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
    Ask FixBot
  11. Lenovo Yoga 3 Pro USB Ports Replacement: step 11, image 1 of 2 Lenovo Yoga 3 Pro USB Ports Replacement: step 11, image 2 of 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
    Ask FixBot
  12. Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: step 12, image 1 of 2 Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: step 12, image 2 of 2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
    Ask FixBot
  13. Lenovo Yoga 3 Pro USB Ports Replacement: step 13, image 1 of 1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
    Ask FixBot
  14. Lenovo Yoga 3 Pro USB Ports Replacement: step 14, image 1 of 1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
    Ask FixBot
  15. Lenovo Yoga 3 Pro USB Ports Replacement: step 15, image 1 of 1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
    Ask FixBot
  16. Lenovo Yoga 3 Pro USB Ports Replacement: step 16, image 1 of 1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
    Ask FixBot
  17. Lenovo Yoga 3 Pro USB Ports Replacement: step 17, image 1 of 1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
    Ask FixBot
  18. Lenovo Yoga 3 Pro USB Ports Replacement: step 18, image 1 of 1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
    Ask FixBot
  19. Lenovo Yoga 3 Pro USB Ports Replacement: step 19, image 1 of 1
    • Remove the USB assembly using the plastic opening tool.
    Ask FixBot
  20. Lenovo Yoga 3 Pro USB Ports Replacement: step 20, image 1 of 1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
    Ask FixBot
  21. Lenovo Yoga 3 Pro USB Ports Replacement: step 21, image 1 of 1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
    Ask FixBot
11 other people completed this guide.
Caroline Seifert
550 Reputation
2 Guides authored
Cal Poly, Team 12-17, Maness Fall 2015 Member of Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Members
15 Guides authored
4 Guide Comments
Repaired customers Yoga 3 that had NO working USB ports whatsoever in less than an hour - after cleaning & replacing (no parts needed)
All USB ports were fully functional once again...
Great job & thank you for the help :)
admin - Reply Share
This guide helped me quite a bit today. I really appreciate you providing it.
Jon Tucich - Reply Share
Can you please help with information on where to get the DC input USB port part. My USB port is broken and unable to find it
Dheeraj - Reply Share
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
ori elyada - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 77
All Time: 14,240
