Lenovo Yoga 3 Pro Screen Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Lenovo Yoga 3 Pro Screen Replacement, Back Panel: step 1, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement, Back Panel: step 1, image 2 of 2
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
    Ask FixBot
  2. Lenovo Yoga 3 Pro Screen Replacement: step 2, image 1 of 1
    • Gently lift the back cover off of the laptop.
    Ask FixBot
  3. Lenovo Yoga 3 Pro Screen Replacement, Battery: step 3, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement, Battery: step 3, image 2 of 2
    • Push the black battery cable towards the battery to disconnect it.
    Ask FixBot
  4. Lenovo Yoga 3 Pro Screen Replacement: step 4, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement: step 4, image 2 of 2
    • Remove the six #0 3.8mm Phillips screws from the battery.
    Ask FixBot
  5. Lenovo Yoga 3 Pro Screen Replacement: step 5, image 1 of 1
    • Gently lift the battery out of the laptop chassis.
    Ask FixBot
  6. Lenovo Yoga 3 Pro Screen Replacement, SSD: step 6, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement, SSD: step 6, image 2 of 2
    • Remove the one #0 2.9mm Phillips screw from the SSD.
    Ask FixBot
  7. Lenovo Yoga 3 Pro Screen Replacement: step 7, image 1 of 1
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
    Ask FixBot
  8. Lenovo Yoga 3 Pro Screen Replacement, Wireless Card: step 8, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement, Wireless Card: step 8, image 2 of 2
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
    Ask FixBot
  9. Lenovo Yoga 3 Pro Screen Replacement: step 9, image 1 of 1
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
    Ask FixBot
  10. Lenovo Yoga 3 Pro Screen Replacement: step 10, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement: step 10, image 2 of 2
    • Gently lift and pull the wifi card out.
    Ask FixBot
  11. Lenovo Yoga 3 Pro Screen Replacement, Motherboard: step 11, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement, Motherboard: step 11, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement, Motherboard: step 11, image 3 of 3
    • Push the cable away from the motherboard.
    Ask FixBot
  12. Lenovo Yoga 3 Pro Screen Replacement: step 12, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 12, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 12, image 3 of 3
    • Remove the two #0 2.9mm Phillips screws from the daughter board.
    Ask FixBot
  13. Lenovo Yoga 3 Pro Screen Replacement: step 13, image 1 of 1
    • Lift the daughter board with the plastic opening tool.
    • You will hear two clicks when lifting the daughter board.
    Ask FixBot
  14. Lenovo Yoga 3 Pro Screen Replacement: step 14, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 14, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 14, image 3 of 3
    • Lift the daughter board, unrouting the wireless cables from their plastic holders, and place it to the side.
    Ask FixBot
  15. Lenovo Yoga 3 Pro Screen Replacement: step 15, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 15, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 15, image 3 of 3
    • Gently lift the metal tabs on the daughter board to free the wires.
    Ask FixBot
  16. Lenovo Yoga 3 Pro Screen Replacement: step 16, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 16, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 16, image 3 of 3
    • Detach the five flat flex cables attached to the motherboard as follows:
    • 1. Flip the cable holder up with a finger nail
    • 2. Pull on the tab to remove the cable.
    • The large black flat flex labeled 'MB' does not have a tab so gently tug the cable free from the end after flipping the cable holder.
    Ask FixBot
  17. Lenovo Yoga 3 Pro Screen Replacement: step 17, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 17, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 17, image 3 of 3
    • Remove the four #0 2.3mm Phillips screws holding down the motherboard.
    • Remove the two #0 2.9mm Phillips screws holding down the fan.
    Ask FixBot
  18. Lenovo Yoga 3 Pro Screen Replacement: step 18, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 18, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 18, image 3 of 3
    • Make sure the motherboard and fan are not caught on anything when flipping it over.
    • Gently lift and flip the motherboard over.
    Ask FixBot
  19. Lenovo Yoga 3 Pro Screen Replacement: step 19, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 19, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 19, image 3 of 3
    • Flip the cable lock holding down the monitor connector.
    • Remove the monitor connector by tugging on the tab.
    Ask FixBot
  20. Lenovo Yoga 3 Pro Screen Replacement, Screen: step 20, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement, Screen: step 20, image 2 of 2
    • Remove the ten #0 3.7mm Phillips screws holding down the monitor assembly.
    Ask FixBot
  21. Lenovo Yoga 3 Pro Screen Replacement: step 21, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 21, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 21, image 3 of 3
    • Flip over the laptop so that it's facing up
    • Gently open the laptop to separate the screen from the laptop chassis.
    Ask FixBot
  22. Lenovo Yoga 3 Pro Screen Replacement: step 22, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement: step 22, image 2 of 2
    • The screw cover is held down with adhesive and is very fragile.
    • Remove the black screw cover from the screen by prying with the wide plastic opening tool.
    • Pull it off slowly.
    Ask FixBot
  23. Lenovo Yoga 3 Pro Screen Replacement: step 23, image 1 of 1
    • Remove the eight #0 2.4mm Phillips screws holding down the monitor.
    Ask FixBot
  24. Lenovo Yoga 3 Pro Screen Replacement: step 24, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 24, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 24, image 3 of 3
    • Insert the wide plastic opening tool between the rubberized plastic and the watchband hinge.
    • Pry the monitor assembly up until you can fit a few fingers under it.
    • Lift until the tabs holding the bottom of the monitor are released.
    Ask FixBot
  25. Lenovo Yoga 3 Pro Screen Replacement: step 25, image 1 of 1
    • Slowly go around the perimeter of the screen with your fingers to loosen all the tabs holding down the monitor.
    Ask FixBot
  26. Lenovo Yoga 3 Pro Screen Replacement: step 26, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement: step 26, image 2 of 2
    • Be careful with the ribbon cable.
    • With the screen facing up, flip the screen assembly over
    Ask FixBot
  27. Lenovo Yoga 3 Pro Screen Replacement: step 27, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 27, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 27, image 3 of 3
    • Disconnect the two monitor connectors with the tips of your fingers.
    Ask FixBot
  28. Lenovo Yoga 3 Pro Screen Replacement: step 28, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 28, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 28, image 3 of 3
    • Remove the flat flex cable by first lifting the hinge then pulling the hinge away from the connector.
    • The hinge may be taped down, so lift the tape and pull the hinge via the tape.
    Ask FixBot
  29. Lenovo Yoga 3 Pro Screen Replacement: step 29, image 1 of 1
    • Peel off the tape holding down the webcam cable.
    Ask FixBot
  30. Lenovo Yoga 3 Pro Screen Replacement: step 30, image 1 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 30, image 2 of 3 Lenovo Yoga 3 Pro Screen Replacement: step 30, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the two cables connecting the webcam.
    • It may be easier to remove the webcam connector with tweezers.
    Ask FixBot
  31. Lenovo Yoga 3 Pro Screen Replacement: step 31, image 1 of 2 Lenovo Yoga 3 Pro Screen Replacement: step 31, image 2 of 2
    • Carefully unroute the webcam connector from the plastic tabs holding it down.
    Ask FixBot
11 other people completed this guide.
Nathan Lui
848 Reputation
5 Guides authored
Cal Poly, Team S13-G6, Forte Spring 2017 Member of Cal Poly, Team S13-G6, Forte Spring 2017
CPSU-FORTE-S17S13G6
4 Members
12 Guides authored
5 Guide Comments
Wrong laptop Screen.
it’s not for 900-13ISK2
https://www.microsoft.com/en-us/store/d/...
3 3 - Reply Share
this is for the 131sk2 not the 131sk ?
i wasn’t aware the was a difference until my screen developed issues. i have read the 131SK is glued to the back panel not clipped in
is there a way to figure this out for sure?
Shawn Thomas - Reply Share
I can confirm that the monitor on my 900 does not have the strip at the bottom of the screen to expose the screws. I have a video on YouTube here. [|https://youtu.be/mBiChrP6MAA] It shows the issue with the video cable, and that the screen is glued all the way around. Thanks for the rest of the info tho
…. and you REALLY don’t have to take apart the entire MOBO and all the DB’s as well, just to replace the screen. All that is handled on the other side of the hinge. So not needed…. in my opinion. Of course, you DO want to disconnect your battery.
Danny B - Reply Share
https://www.youtube.com/watch?v=SEwizLj_... this shows what to do for the 900-131sk2
ronald baer - Reply Share
Is there any link that can direct the user to access any video on how to fix it?
ROBERT MENSAH BANYO OKRAH - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 51
All Time: 16,898
