Lenovo Yoga 3 Pro Display Assembly Replacement
  1. Lenovo Yoga 3 Pro Display Assembly Replacement, Battery: step 1, image 1 of 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
    Ask FixBot
  2. Lenovo Yoga 3 Pro Display Assembly Replacement: step 2, image 1 of 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
    Ask FixBot
  3. Lenovo Yoga 3 Pro Display Assembly Replacement: step 3, image 1 of 1
    • Remove the panel and place it in a safe location.
    Ask FixBot
  4. Lenovo Yoga 3 Pro Display Assembly Replacement: step 4, image 1 of 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
    Ask FixBot
  5. Lenovo Yoga 3 Pro Display Assembly Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
    Ask FixBot
  6. Lenovo Yoga 3 Pro Display Assembly Replacement: step 6, image 1 of 1
    • Carefully lift and remove the battery.
    Ask FixBot
  7. Lenovo Yoga 3 Pro Display Assembly Replacement, Speakers: step 7, image 1 of 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
    Ask FixBot
  8. Lenovo Yoga 3 Pro Display Assembly Replacement: step 8, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 8, image 2 of 2
    • Using the plastic opening tool, flip open tab as shown.
    Ask FixBot
  9. Lenovo Yoga 3 Pro Display Assembly Replacement: step 9, image 1 of 3 Lenovo Yoga 3 Pro Display Assembly Replacement: step 9, image 2 of 3 Lenovo Yoga 3 Pro Display Assembly Replacement: step 9, image 3 of 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
    Ask FixBot
  10. Lenovo Yoga 3 Pro Display Assembly Replacement: step 10, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 10, image 2 of 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
    Ask FixBot
  11. Lenovo Yoga 3 Pro Display Assembly Replacement: step 11, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 11, image 2 of 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
    Ask FixBot
  12. Lenovo Yoga 3 Pro Display Assembly Replacement, USB Ports: step 12, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement, USB Ports: step 12, image 2 of 2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
    Ask FixBot
  13. Lenovo Yoga 3 Pro Display Assembly Replacement: step 13, image 1 of 1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
    Ask FixBot
  14. Lenovo Yoga 3 Pro Display Assembly Replacement: step 14, image 1 of 1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
    Ask FixBot
  15. Lenovo Yoga 3 Pro Display Assembly Replacement: step 15, image 1 of 1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
    Ask FixBot
  16. Lenovo Yoga 3 Pro Display Assembly Replacement: step 16, image 1 of 1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
    Ask FixBot
  17. Lenovo Yoga 3 Pro Display Assembly Replacement: step 17, image 1 of 1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
    Ask FixBot
  18. Lenovo Yoga 3 Pro Display Assembly Replacement: step 18, image 1 of 1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
    Ask FixBot
  19. Lenovo Yoga 3 Pro Display Assembly Replacement: step 19, image 1 of 1
    • Remove the USB assembly using the plastic opening tool.
    Ask FixBot
  20. Lenovo Yoga 3 Pro Display Assembly Replacement: step 20, image 1 of 1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
    Ask FixBot
  21. Lenovo Yoga 3 Pro Display Assembly Replacement: step 21, image 1 of 1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
    Ask FixBot
  22. Lenovo Yoga 3 Pro Display Assembly Replacement, Display Assembly: step 22, image 1 of 1
    • Remove the four 2mm screws using the Philips 00 screwdriver.
    • Remove the 2.5mm screw using the Philips 00 screwdriver.
    Ask FixBot
  23. Lenovo Yoga 3 Pro Display Assembly Replacement: step 23, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 23, image 2 of 2
    • Open the three ribbon connecting tabs.
    Ask FixBot
  24. Lenovo Yoga 3 Pro Display Assembly Replacement: step 24, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 24, image 2 of 2
    • Lift the board with the plastic opening tool.
    • Be careful lifting the board.
    • Open the pin connector.
    • Do not lift the board completely so as not to pull the ribbon connector.
    Ask FixBot
  25. Lenovo Yoga 3 Pro Display Assembly Replacement: step 25, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 25, image 2 of 2
    • Remove the ten 3.5mm screws using the Philips 00 screwdriver.
    • Lay the laptop as shown.
    Ask FixBot
  26. Lenovo Yoga 3 Pro Display Assembly Replacement: step 26, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 26, image 2 of 2
    • Use a spudger to lift the screw cover.
    • Lift slowly and carefully. The cover is very fragile.
    Ask FixBot
  27. Lenovo Yoga 3 Pro Display Assembly Replacement: step 27, image 1 of 1
    • Remove the eight 2mm screws using the Philips 00 screw driver.
    Ask FixBot
  28. Lenovo Yoga 3 Pro Display Assembly Replacement: step 28, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 28, image 2 of 2
    • Use the plastic opening tool to lift the screen cover from the screen assembly.
    • Do not insert the plastic opener too far in.
    • Slowly go around the perimeter of the screen to loosen all fasteners.
    Ask FixBot
  29. Lenovo Yoga 3 Pro Display Assembly Replacement: step 29, image 1 of 2 Lenovo Yoga 3 Pro Display Assembly Replacement: step 29, image 2 of 2
    • Unclip the display assembly by sliding the display down, towards the lower edge of the upper case component. The clips will disengage and you will be able to lift the assembly out easily.
    • Be careful pulling off the assembly as to not rip the ribbon connector shown.
    Ask FixBot
11 other people completed this guide.
Federico LopezCasildo Jr
1,355 Reputation
3 Guides authored
Cal Poly, Team 12-17, Maness Fall 2015 Member of Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Members
15 Guides authored
2 Guide Comments
Thank you. Very useful.
SHINE K. RAJU - Reply Share
Great guide, but I think you missed the part of removing the fan
302302302v - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 63
All Time: 23,063
