Lenovo Yoga 3 11 Trackpad Replacement
    1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: step 1, image 1 of 1
      • Remove the eleven 6 mm T5 Torx screws securing the lower case.
      • Gently lift the lower case up and away from the device.
      Ask FixBot
    1. Lenovo Yoga 3 11 Trackpad Replacement, Battery: step 2, image 1 of 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: step 2, image 2 of 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: step 2, image 3 of 3
      • Remove the two 3 mm Phillips #00 screws securing the battery.
      • There are arrows on the battery indicating the location of the screws.
      Ask FixBot
    2. Lenovo Yoga 3 11 Trackpad Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to gently disconnect the battery connector.
      Ask FixBot
    3. Lenovo Yoga 3 11 Trackpad Replacement: step 4, image 1 of 2 Lenovo Yoga 3 11 Trackpad Replacement: step 4, image 2 of 2
      • Use a pair of tweezers to gently disconnect the speaker cable.
      • Remove the wires from underneath the battery tabs using the tweezers.
      Ask FixBot
    4. Lenovo Yoga 3 11 Trackpad Replacement: step 5, image 1 of 1
      • Carefully remove the battery from the device.
      Ask FixBot
    1. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: step 6, image 1 of 1
      • Remove the four 2 mm Phillips #0 securing the trackpad.
      Ask FixBot
    2. Lenovo Yoga 3 11 Trackpad Replacement: step 7, image 1 of 1
      Buy
      • Use the tweezers to partially remove the tape.
      Ask FixBot
    3. Lenovo Yoga 3 11 Trackpad Replacement: step 8, image 1 of 2 Lenovo Yoga 3 11 Trackpad Replacement: step 8, image 2 of 2
      • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
      Ask FixBot
    4. Lenovo Yoga 3 11 Trackpad Replacement: step 9, image 1 of 2 Lenovo Yoga 3 11 Trackpad Replacement: step 9, image 2 of 2
      • Slightly push down with your thumb to pop out the trackpad.
      • The laptop must be slightly open in order for the trackpad to pop out.
      Ask FixBot
Slade Fernandes
553 Reputation
3 Guides authored
USF Tampa, Team 2-3, Blackwell Fall 2015 Member of USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Members
71 Guides authored
1 Guide Comment
Very brief, great illustrations. Now, I need to try it.
M T Martinez - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 3,260
