Lenovo Yoga 2 13" Keyboard Keys Replacement
Views: 19K
View statistics:
Past 24 Hours:
2
Past 7 Days:
34
Past 30 Days:
116
All Time:
18,818
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will explain how to safely remove a specific key from the keyboard of your Lenovo Yoga 2 13". It will provide a list of the tools needed as well as the easiest way to remove the key.
Tools
    1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: step 1, image 1 of 2 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: step 1, image 2 of 2
      • Using a flat tool, carefully jimmy the selected key until it pops out.
      Ask FixBot
    2. Lenovo Yoga 2 13" Keyboard Keys Replacement: step 2, image 1 of 1
      • To insert a new key, simply place and apply pressure until it snaps into place.
      Ask FixBot
Nichelle
1,568 Reputation
5 Guides authored
Marist, Team 1-2, Laflen Spring 2015 Member of Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Members
60 Guides authored
4 Guide Comments
this doesn't fix a non-working electric contact, does it?
Simon - Reply Share
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - Reply Share
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - Reply Share
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - Reply Share
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 116
All Time: 18,818
