Lenovo Yoga 2 11" Battery Replacement
Views: 28K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
137
All Time:
27,906
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
As time passes, a battery loses its capability to hold a single charge. This guide will aide users in removing the back panel to reach and replace the faulty battery. Remember to turn the laptop off prior to the repair.
Parts
Tools
    1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: step 1, image 1 of 1
      • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
      Ask FixBot
    2. Lenovo Yoga 2 11" Battery Replacement: step 2, image 1 of 1
      • Carefully separate back panel from laptop.
      Ask FixBot
    1. Lenovo Yoga 2 11" Battery Replacement, Battery: step 3, image 1 of 1
      • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
      Ask FixBot
    2. Lenovo Yoga 2 11" Battery Replacement: step 4, image 1 of 1
      • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
      Ask FixBot
    3. Lenovo Yoga 2 11" Battery Replacement: step 5, image 1 of 2 Lenovo Yoga 2 11" Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
      Ask FixBot
    4. Lenovo Yoga 2 11" Battery Replacement: step 6, image 1 of 1
      • Once all of the wires are detached, carefully remove the battery and replace.
      Ask FixBot
12 other people completed this guide.
Abbey Hickmann
197 Reputation
1 Guide authored
Cal Poly, Team 4-3, Maness Fall 2015 Member of Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Members
60 Guides authored
4 Guide Comments
how do I remove unathorized battery error?
Manuel Durugas - Reply Share
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Reply Share
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Reply Share
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 137
All Time: 27,906
