Lenovo Yoga 2 11" Back Panel Replacement
    1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
      Ask FixBot
    2. Lenovo Yoga 2 11" Back Panel Replacement: step 2, image 1 of 1
      • Carefully separate back panel from laptop.
      Ask FixBot
3 other people completed this guide.
Peyton Leeson
939 Reputation
4 Guides authored
Cal Poly, Team 4-3, Maness Fall 2015 Member of Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Members
60 Guides authored
3 Guide Comments
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Reply Share
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Reply Share
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 103
All Time: 5,490
