Lenovo Yoga 2 11" 20428 Keyboard Replacement
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Back Panel: step 1, image 1 of 3 Lenovo Yoga 2 11" 20428 Keyboard Replacement, Back Panel: step 1, image 2 of 3 Lenovo Yoga 2 11" 20428 Keyboard Replacement, Back Panel: step 1, image 3 of 3
      • Flip the computer over so the bottom is facing up.
      • Remove the ten 6mm screws with a T5 Torx security screwdriver.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 2, image 1 of 1
      • Carefully remove the back panel by gently separating the panel from front to back.
      • Take care not to pull any wires or crack the outer shell.
      Ask FixBot
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Battery: step 3, image 1 of 3 Lenovo Yoga 2 11" 20428 Keyboard Replacement, Battery: step 3, image 2 of 3 Lenovo Yoga 2 11" 20428 Keyboard Replacement, Battery: step 3, image 3 of 3
      • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
      • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 4, image 1 of 1
      • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
      Ask FixBot
    3. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 5, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 5, image 2 of 2
      • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
      • If possible, do not to pull the connector out by the wires, as this can damage the connector.
      Ask FixBot
    4. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 6, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 6, image 2 of 2
      • Carefully remove the battery from the laptop.
      • Take care not to pull out the Bluetooth antenna while removing the battery.
      Ask FixBot
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Speaker: step 7, image 1 of 1
      • Use the Phillips #000 screwdriver to unscrew the four 1.7 mm screws.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 8, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 8, image 2 of 2
      • Carefully detach the speaker wire and remove the speaker.
      Ask FixBot
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Hard Drive: step 9, image 1 of 1
      • Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 10, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 10, image 2 of 2
      • Lift the hard drive up, turn it over, and remove the connection.
      Ask FixBot
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Bluetooth Module: step 11, image 1 of 1
      • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 12, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 12, image 2 of 2
      • Gently grab and remove the Bluetooth module.
      Ask FixBot
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Motherboard: step 13, image 1 of 1
      • Using your finger nail or a thin pry tool, unlock and remove the three cables.
      • Lift the two pieces of tape. Carefully pull the cable connector back to remove it from the motherboard.
      • Use the Phillips #000 screwdriver to remove the eight 3.8mm screws.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 14, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 14, image 2 of 2
      • Gently pull the cable out of the connector.
      Ask FixBot
    3. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 15, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 15, image 2 of 2
      • Lift the wide cable in the center to reveal the port for the small cable underneath.
      • Using a fingernail or a thin pry tool, lift the white bar to release the cable.
      • Remove the cable from the connector.
      Ask FixBot
    4. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 16, image 1 of 1
      • Lift the tape up to separate it from the motherboard.
      • Using a fingernail or a thin pry tool, lift the connector upwards to separate from the motherboard.
      Ask FixBot
    5. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 17, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 17, image 2 of 2
      • Remove the black tape covering the connector.
      • Pull straight backwards to remove the connector from the motherboard.
      Ask FixBot
    6. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 18, image 1 of 1
      • Pull the cable straight backwards to remove it.
      Ask FixBot
    7. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 19, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 19, image 2 of 2
      Ask FixBot
    8. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 20, image 1 of 2 Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 20, image 2 of 2
      • Use the Phillips #000 screwdriver to remove the seven 3.6mm screws.
      Ask FixBot
    9. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 21, image 1 of 1
      • Lift and pull backwards to remove the motherboard.
      Ask FixBot
    1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Keyboard: step 22, image 1 of 1
      • Use the Phillips #000 screwdriver to unscrew and remove the one 3.3 mm screw that secures the daughterboard.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 23, image 1 of 1
      • Gently remove the daughterboard.
      Ask FixBot
    3. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 24, image 1 of 1
      • Carefully remove all of the small black clips along the edge of the metal piece.
      Ask FixBot
    4. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 25, image 1 of 1
      • Gently lift up and remove the two metal pieces, at the back of the bottom case, near the hinges.
      Ask FixBot
    5. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 26, image 1 of 1
      • Gently lift up the metal cover and remove it.
      Ask FixBot
    6. Lenovo Yoga 2 11" 20428 Keyboard Replacement: step 27, image 1 of 1
      • Gently lift up the keyboard base and remove it.
      Ask FixBot
To reassemble your Lenovo Yoga 2 11" (model 20428) keyboard, follow these instructions in reverse order.
Shalem
163 Reputation
1 Guide authored
IUPUI, Team 1-3, Harley Spring 2022 Member of IUPUI, Team 1-3, Harley Spring 2022
IUPUI-HARLEY-S22S1G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,014
