Lenovo Yoga 2 11" 20428 Display Replacement
    1. Lenovo Yoga 2 11" 20428 Display Replacement, Display: step 1, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement, Display: step 1, image 2 of 2
      • Remove the plastic square covers on the hinge cover.
      Ask FixBot
    2. Lenovo Yoga 2 11" 20428 Display Replacement: step 2, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 2, image 2 of 2
      • Remove the two 3.8 mm screws from the hinge cover.
      Ask FixBot
    3. Lenovo Yoga 2 11" 20428 Display Replacement: step 3, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 3, image 2 of 2
      • Remove the hinge cover.
      Ask FixBot
    4. Lenovo Yoga 2 11" 20428 Display Replacement: step 4, image 1 of 3 Lenovo Yoga 2 11" 20428 Display Replacement: step 4, image 2 of 3 Lenovo Yoga 2 11" 20428 Display Replacement: step 4, image 3 of 3
      • Remove the 2.8mm screws.
      • Remove the 5mm screws.
      • Remove the 2.4mm screws.
      Ask FixBot
    5. Lenovo Yoga 2 11" 20428 Display Replacement: step 5, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 5, image 2 of 2
      • Remove the front cover of the display
      Ask FixBot
    6. Lenovo Yoga 2 11" 20428 Display Replacement: step 6, image 1 of 1
      • Unplug the button sensor board.
      • Do not damage the teeth. Damaging the teeth of the sensor board may require you to replace the part.
      Ask FixBot
    7. Lenovo Yoga 2 11" 20428 Display Replacement: step 7, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 7, image 2 of 2
      • Remove the 2.1 mm screws from the brightness sensor board.
      Ask FixBot
    8. Lenovo Yoga 2 11" 20428 Display Replacement: step 8, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 8, image 2 of 2
      • Remove the 3.3 mm screw on the camera.
      • Removal of the camera will result in the connecting wire to be disconnected as well
      Ask FixBot
    9. Lenovo Yoga 2 11" 20428 Display Replacement: step 9, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 9, image 2 of 2
      • Remove the 3.3 mm screw on the touch control board.
      Ask FixBot
    10. Lenovo Yoga 2 11" 20428 Display Replacement: step 10, image 1 of 2 Lenovo Yoga 2 11" 20428 Display Replacement: step 10, image 2 of 2
      • Remove the touch control board
      • Do not damage the teeth. Damaging the teeth may call for replacement of the part.
      • Removal of the touch control board will result in the connecting wires to be removed as well
      Ask FixBot
Devin McCuen
181 Reputation
1 Guide authored
IUPUI, Team 1-3, Harley Spring 2022 Member of IUPUI, Team 1-3, Harley Spring 2022
IUPUI-HARLEY-S22S1G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 38
All Time: 669
