Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
117
All Time:
5,675
Comments: 1
1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
You will be removing the back panel, disconecting the
battery and upgrading/replacing the RAM.
Tools
    1. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: step 1, image 1 of 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: step 1, image 2 of 2
      • Unscrew and take out 10, 1/5 cm screws.
      • Unscrew and take out 1, 1 inch screw.
      • I use a piece of tape sticky side up to place screws on, also I label it where they go.
      Ask FixBot
    2. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: step 2, image 1 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: step 2, image 2 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: step 2, image 3 of 3
      • With the vents facing away from your body I find it easiest to start at the bottom right corner first and gently pry up the corner using a plastic tool.
      • Then slide and pry the plastic tool to the left corner.
      • Then work on the sides.
      Ask FixBot
    3. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: step 3, image 1 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: step 3, image 2 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: step 3, image 3 of 3
      • Carefully lift up on the back panel.
      • The back will snap out of place but be careful and don't force it to hard.
      Ask FixBot
    4. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: step 4, image 1 of 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: step 4, image 2 of 2
      • Pull the battery cable out of it's connector. Gripping the wires in the middle gently wiggling the wires back and forth while pulling.
      • With the battery connector out.
      Ask FixBot
    5. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: step 5, image 1 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: step 5, image 2 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: step 5, image 3 of 3
      • Note the tabs on each side of the RAM holder,
      • With your fingers or the plastic tool gently move the tabs away from the RAM, the RAM should pop up when both sides or moved.
      • Grip the RAM by the sides and lift out.
      Ask FixBot
8 other people completed this guide.
Corbin Schon
674 Reputation
2 Guides authored
1 Guide Comment
Thank you for the guide! It helped me to feel sure about the disassemble.
cacalo219 - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 117
All Time: 5,675
