Lenovo Y520-15IKBN Display Replacement
    1. Lenovo Y520-15IKBN Display Replacement, Battery: step 1, image 1 of 2 Lenovo Y520-15IKBN Display Replacement, Battery: step 1, image 2 of 2
      • Remove the four 4 mm Phillips #00 screws securing the battery.
      Ask FixBot
    2. Lenovo Y520-15IKBN Display Replacement: step 2, image 1 of 2 Lenovo Y520-15IKBN Display Replacement: step 2, image 2 of 2
      • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
      • Do not pull on the socket itself or you risk damaging the motherboard.
      • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
      Ask FixBot
    3. Lenovo Y520-15IKBN Display Replacement: step 3, image 1 of 1
      • Lift the battery up and out of the chassis.
      Ask FixBot
    1. Lenovo Y520-15IKBN Display Replacement, Display: step 4, image 1 of 1
      • Use an opening tool to pry off the display bezel.
      Ask FixBot
    2. Lenovo Y520-15IKBN Display Replacement: step 5, image 1 of 1
      • Remove the four 4 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    3. Lenovo Y520-15IKBN Display Replacement: step 6, image 1 of 1
      • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
      • Remove the display from the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 65
All Time: 2,422
