Lenovo Y50-70 Touch Trackpad Replacement
    1. Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: step 1, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: step 1, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: step 1, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
      • Grab and pull off the back.
      Ask FixBot
    2. Lenovo Y50-70 Touch Trackpad Replacement: step 2, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 2, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
      • Grab the battery cable and gently pull it free from the cable connector.
      • Remove the battery from the laptop.
      Ask FixBot
    3. Lenovo Y50-70 Touch Trackpad Replacement: step 3, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 3, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
      • Grab the marked cable attached to the hard drive, and gently pull to unplug.
      • Remove the hard drive from the laptop.
      Ask FixBot
    4. Lenovo Y50-70 Touch Trackpad Replacement: step 4, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 4, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 4, image 3 of 3
      • Grab marked cables and pull them out from their plug-in.
      Ask FixBot
    5. Lenovo Y50-70 Touch Trackpad Replacement: step 5, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 5, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 5, image 3 of 3
      • Grab the top set of marked cables and pull up to remove them.
      • Grab the lower marked cable and pull it out from the plug.
      Ask FixBot
    6. Lenovo Y50-70 Touch Trackpad Replacement: step 6, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 6, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 6, image 3 of 3
      • Grab marked cables and pull up to unplug.
      Ask FixBot
    7. Lenovo Y50-70 Touch Trackpad Replacement: step 7, image 1 of 2 Lenovo Y50-70 Touch Trackpad Replacement: step 7, image 2 of 2
      • Grab the marked cable and pull out to unplug.
      Ask FixBot
    8. Lenovo Y50-70 Touch Trackpad Replacement: step 8, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 8, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 8, image 3 of 3
      • Grab the black tab on top of the cable and pull up to unplug.
      Ask FixBot
    9. Lenovo Y50-70 Touch Trackpad Replacement: step 9, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 9, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 9, image 3 of 3
      • Lift the black tab on top of the marked cable.
      • Grab the colored tab on the cable and pull to remove the cable.
      Ask FixBot
    10. Lenovo Y50-70 Touch Trackpad Replacement: step 10, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 10, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 10, image 3 of 3
      Ask FixBot
    11. Lenovo Y50-70 Touch Trackpad Replacement: step 11, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 11, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 11, image 3 of 3
      Ask FixBot
    12. Lenovo Y50-70 Touch Trackpad Replacement: step 12, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 12, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 12, image 3 of 3
      • Lift the black tab on top of the marked cables.
      • Grab the colored tab on the cables and pull to remove the cables.
      Ask FixBot
    13. Lenovo Y50-70 Touch Trackpad Replacement: step 13, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 13, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 13, image 3 of 3
      • Carefully remove the yellow tape on top of the cable.
      Ask FixBot
    14. Lenovo Y50-70 Touch Trackpad Replacement: step 14, image 1 of 2 Lenovo Y50-70 Touch Trackpad Replacement: step 14, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
      • Grab and lift the heatsink off the motherboard.
      Ask FixBot
    15. Lenovo Y50-70 Touch Trackpad Replacement: step 15, image 1 of 2 Lenovo Y50-70 Touch Trackpad Replacement: step 15, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
      • Grab and lift the motherboard up and out from the laptop.
      Ask FixBot
    16. Lenovo Y50-70 Touch Trackpad Replacement: step 16, image 1 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 16, image 2 of 3 Lenovo Y50-70 Touch Trackpad Replacement: step 16, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew and remove the two 6 mm screws at the top of the trackpad.
      • Push on the marked clips at the top of the trackpad.
      • Then, when undone from clips, lift the trackpad out from the laptop.
      Ask FixBot
Ryan McCann
305 Reputation
1 Guide authored
IUPUI, Team 6-6, Beck Spring 2022 Member of IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 Members
29 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 40
All Time: 1,126
