Lenovo Y50-70 Touch Fan Replacement
  1. Lenovo Y50-70 Touch Fan Replacement, Back: step 1, image 1 of 2 Lenovo Y50-70 Touch Fan Replacement, Back: step 1, image 2 of 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
    Ask FixBot
  2. Lenovo Y50-70 Touch Fan Replacement: step 2, image 1 of 2 Lenovo Y50-70 Touch Fan Replacement: step 2, image 2 of 2
    • Gently pull the back cover off the laptop. It should come off easily.
    Ask FixBot
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: step 3, image 1 of 2 Lenovo Y50-70 Touch Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
    Ask FixBot
  4. Lenovo Y50-70 Touch Fan Replacement: step 4, image 1 of 3 Lenovo Y50-70 Touch Fan Replacement: step 4, image 2 of 3 Lenovo Y50-70 Touch Fan Replacement: step 4, image 3 of 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
    Ask FixBot
  5. Lenovo Y50-70 Touch Fan Replacement: step 5, image 1 of 3 Lenovo Y50-70 Touch Fan Replacement: step 5, image 2 of 3 Lenovo Y50-70 Touch Fan Replacement: step 5, image 3 of 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
    Ask FixBot
  6. Lenovo Y50-70 Touch Fan Replacement: step 6, image 1 of 3 Lenovo Y50-70 Touch Fan Replacement: step 6, image 2 of 3 Lenovo Y50-70 Touch Fan Replacement: step 6, image 3 of 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
    Ask FixBot
  7. Lenovo Y50-70 Touch Fan Replacement: step 7, image 1 of 2 Lenovo Y50-70 Touch Fan Replacement: step 7, image 2 of 2
    • Lift the fan off of the laptop.
    Ask FixBot
8 other people completed this guide.
Vivian
351 Reputation
1 Guide authored
Cal Poly, Team 18-1, Maness Winter 2015 Member of Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 27
All Time: 9,865
