This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓This guide explains how to assemble a Restart PC using a Lenovo X270 motherboard: wiring and gluing the power button and LED, installing the rear connector blocks, and mounting the motherboard and SSD into the housing.
Tools
Replace the BIOS battery.
Add a RAM stick.
Start the board with the Windows disk already installed (it has a sticky note).
Install the button on the front panel.
Add solder to the button terminals.
Tin the black and white wires.
Solder the wires to the button terminals.
Use the heat gun to install the heat shrink tubing.
Insert the seal, then tighten the nut.
Insert a long USB extension.
Ensure the "blue USB bars" on the extension are facing upward (see photo).
Secure the connector with 2 Phillips M3 screws.
Drive the 4 M2 screws (see location in photo).
Also install the speaker onto its bracket using 2 screws (see photo).
Drive the 2 short M3 top screws WITHOUT TIGHTENING.
Flip the assembly over.
Insert a drop of threadlocker into the 2 free holes.
Drive the 2 remaining screws in without overtightening at the end.
Remove the 2 top screws and reinstall them after applying threadlocker.
Tighten the 2 top screws firmly.
For the left-hand connection, you must use a U-turn USB adapter (180° black).
Route the cables under the motherboard.
Apply a drop of threadlocker.
Install one short M3 Torx screw per block WITHOUT TIGHTENING.
Once all the blocks are installed, tighten the screws one by one.
2x solid block.
1x hub block.
1x HDMI block.
1x USB-C power block.
1x RJ45 block.
Add a drop of threadlocker into the M2 insert. This is located at the front of the PC, on the side opposite the USB port.
Drive an M2 screw.
Connect the USB extension socket.
Add a zip tie to the HDMI cables and the adjacent USB-A cable.
Trim the excess with flush cutters.
Hide the "knot" under the cable.
Secure the air duct with 2 Phillips M2 screws.
Repeat the green points for the dust screen.
Connect the Wi-Fi antennas.
The blue antenna goes on the USB socket side.
The orange antenna goes on the air scoop side.
Use a cable tie to organize the cables.
Apply a bead of hot glue to the power button board connector.
Install the upper plate.
Secure with 4 black M3 Phillips flat-head screws (skip this step if parts are missing).
