Lenovo X200 Memory Replacement
    1. Lenovo X200 Memory Replacement, Memory: step 1, image 1 of 1
      • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
      Ask FixBot
    2. Lenovo X200 Memory Replacement: step 2, image 1 of 1
      • 2. Remove the panel to access the memory modules.
      Ask FixBot
    3. Lenovo X200 Memory Replacement: step 3, image 1 of 1
      • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
      • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
      • Insert the notched end of the DIMM into the socket.
      • Press the DIMM firmly, and pivot it until it snaps into the place.
      • Make sure that it is firmly fixed in the slot and does not move easily.
      Ask FixBot
4 other people completed this guide.
James Finch
2,734 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 83
All Time: 2,240
