Lenovo V15-ADA RAM Replacement
    1. Lenovo V15-ADA RAM Replacement, Back Panel Assembly: step 1, image 1 of 2 Lenovo V15-ADA RAM Replacement, Back Panel Assembly: step 1, image 2 of 2
      • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
      • M2.5 × 7 mm, Phillips-head (6) (RED circles)
      • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
      • The red circles show the longer screws, and the orange circles show the shorter screws.
      • Keep your screws organized. They’re different lengths and must go back in their original positions.
      Ask FixBot
    2. Lenovo V15-ADA RAM Replacement: step 2, image 1 of 2 Lenovo V15-ADA RAM Replacement: step 2, image 2 of 2
      • After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
      • Gently slide the tool around the edges until the clips begin to release.
      • Once all the clips are loose, lift the cover off and set it aside.
      • The Wi-Fi card is located near one corner of the motherboard. It has two antenna wires connected to it (one black and one gray).
      Ask FixBot
    1. Lenovo V15-ADA RAM Replacement, RAM: step 3, image 1 of 1
      • Push the clamps holding the RAM card in place back.
      Ask FixBot
    2. Lenovo V15-ADA RAM Replacement: step 4, image 1 of 1
      • Lift out RAM card.
      Ask FixBot
    3. Lenovo V15-ADA RAM Replacement: step 5, image 1 of 1
      • Pull RAM card out.
      Ask FixBot
    4. Lenovo V15-ADA RAM Replacement: step 6, image 1 of 1
      • After completing steps 5-7, the RAM is successfully removed.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 87
All Time: 793
