Lenovo V15-ADA Back Panel Assembly Replacement
    1. Lenovo V15-ADA Back Panel Assembly Replacement, Back Panel Assembly: step 1, image 1 of 2 Lenovo V15-ADA Back Panel Assembly Replacement, Back Panel Assembly: step 1, image 2 of 2
      • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
      • M2.5 × 7 mm, Phillips-head (6) (RED circles)
      • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
      • The red circles show the longer screws, and the orange circles show the shorter screws.
      • Keep your screws organized. They’re different lengths and must go back in their original positions.
      Ask FixBot
    2. Lenovo V15-ADA Back Panel Assembly Replacement: step 2, image 1 of 2 Lenovo V15-ADA Back Panel Assembly Replacement: step 2, image 2 of 2
      • After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
      • Gently slide the tool around the edges until the clips begin to release.
      • Once all the clips are loose, lift the cover off and set it aside.
      • The Wi-Fi card is located near one corner of the motherboard. It has two antenna wires connected to it (one black and one gray).
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 85
All Time: 916
