Lenovo V14-IIL Fan Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
81
All Time:
673
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Fan damage or normal wear may cause the computer to overheat during use. This guide shows how to replace the fan within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Tools
    1. Lenovo V14-IIL Fan Replacement, Back Panel: step 1, image 1 of 2 Lenovo V14-IIL Fan Replacement, Back Panel: step 1, image 2 of 2
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
      • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo V14-IIL Fan Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
      • You may need to move the tool to different locations to fully release the back cover.
      Ask FixBot
    3. Lenovo V14-IIL Fan Replacement: step 3, image 1 of 1
      • Lift away the back panel and set it aside.
      Ask FixBot
    1. Lenovo V14-IIL Fan Replacement, Fan: step 4, image 1 of 2 Lenovo V14-IIL Fan Replacement, Fan: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the three 6 mm screws holding the fan.
      Ask FixBot
    2. Lenovo V14-IIL Fan Replacement: step 5, image 1 of 3 Lenovo V14-IIL Fan Replacement: step 5, image 2 of 3 Lenovo V14-IIL Fan Replacement: step 5, image 3 of 3
      • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
      • Remove the LAN cables from the three brackets on the fan.
      Ask FixBot
    3. Lenovo V14-IIL Fan Replacement: step 6, image 1 of 1
      • Lift out the fan gently pulling until the four cables disconnect from the motherboard.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 81
All Time: 673
