Lenovo V14-IIL Display Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
72
All Time:
404
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Lenovo V14-IIL Display Assembly Replacement, Back Panel: step 1, image 1 of 2 Lenovo V14-IIL Display Assembly Replacement, Back Panel: step 1, image 2 of 2
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
      • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo V14-IIL Display Assembly Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
      • You may need to move the tool to different locations to fully release the back cover.
      Ask FixBot
    3. Lenovo V14-IIL Display Assembly Replacement: step 3, image 1 of 1
      • Lift away the back panel and set it aside.
      Ask FixBot
    1. Lenovo V14-IIL Display Assembly Replacement, Display Assembly: step 4, image 1 of 2 Lenovo V14-IIL Display Assembly Replacement, Display Assembly: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
      Ask FixBot
    2. Lenovo V14-IIL Display Assembly Replacement: step 5, image 1 of 1
      • Lift up the latch and gently pull the display cable free.
      Ask FixBot
    3. Lenovo V14-IIL Display Assembly Replacement: step 6, image 1 of 2 Lenovo V14-IIL Display Assembly Replacement: step 6, image 2 of 2
      • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
      • Remove the LAN cables from the three brackets on the fan.
      Ask FixBot
    4. Lenovo V14-IIL Display Assembly Replacement: step 7, image 1 of 1
      • Ensure that all cables and hinges are detached.
      • Lift the display assembly away from the base.
      Ask FixBot
Kristen Gismondi
109,535 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 72
All Time: 404
