Lenovo V14-IIL Camera Replacement
    1. Lenovo V14-IIL Camera Replacement, Back Panel: step 1, image 1 of 2 Lenovo V14-IIL Camera Replacement, Back Panel: step 1, image 2 of 2
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
      • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo V14-IIL Camera Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
      • You may need to move the tool to different locations to fully release the back cover.
      Ask FixBot
    3. Lenovo V14-IIL Camera Replacement: step 3, image 1 of 1
      • Lift away the back panel and set it aside.
      Ask FixBot
    1. Lenovo V14-IIL Camera Replacement, Display Assembly: step 4, image 1 of 2 Lenovo V14-IIL Camera Replacement, Display Assembly: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
      Ask FixBot
    2. Lenovo V14-IIL Camera Replacement: step 5, image 1 of 1
      • Lift up the latch and gently pull the display cable free.
      Ask FixBot
    3. Lenovo V14-IIL Camera Replacement: step 6, image 1 of 2 Lenovo V14-IIL Camera Replacement: step 6, image 2 of 2
      • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
      • Remove the LAN cables from the three brackets on the fan.
      Ask FixBot
    4. Lenovo V14-IIL Camera Replacement: step 7, image 1 of 1
      • Ensure that all cables and hinges are detached.
      • Lift the display assembly away from the base.
      Ask FixBot
    1. Lenovo V14-IIL Camera Replacement, Screen Bezel: step 8, image 1 of 2 Lenovo V14-IIL Camera Replacement, Screen Bezel: step 8, image 2 of 2
      • Slide the cable hinge cover to the right.
      • Pull the part away from the screen.
      Ask FixBot
    2. Lenovo V14-IIL Camera Replacement: step 9, image 1 of 2 Lenovo V14-IIL Camera Replacement: step 9, image 2 of 2
      • Use the iFixit opening tool to separate the bezel panel.
      • Slide the opening tool all the way around to loosen the bezels on all sides.
      • You may need to use the tool to gently loosen the adhesive tape.
      • Lift away the bezel panel.
      Ask FixBot
    1. Lenovo V14-IIL Camera Replacement, Camera: step 10, image 1 of 1
      • Gently pull out the stretch adhesive tape.
      • Make sure to pull from hinges to the top of the LCD panel.
      • You may need to use the metal spudger to help loosen the adhesive.
      Ask FixBot
    2. Lenovo V14-IIL Camera Replacement: step 11, image 1 of 1
      • Disconnect the wire from the back of the integrated camera and lift the camera away.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 80
All Time: 614
