Lenovo V14-IIL Battery Replacement
  1. Lenovo V14-IIL Battery Replacement, Back Panel: step 1, image 1 of 2 Lenovo V14-IIL Battery Replacement, Back Panel: step 1, image 2 of 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
    Ask FixBot
  2. Lenovo V14-IIL Battery Replacement: step 2, image 1 of 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
    Ask FixBot
  3. Lenovo V14-IIL Battery Replacement: step 3, image 1 of 1
    • Lift away the back panel and set it aside.
    Ask FixBot
  4. Lenovo V14-IIL Battery Replacement, Battery: step 4, image 1 of 2 Lenovo V14-IIL Battery Replacement, Battery: step 4, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the three 5mm screws holding the battery.
    Ask FixBot
  5. Lenovo V14-IIL Battery Replacement: step 5, image 1 of 1
    • Detach the battery's cable connector from the laptop.
    • Lift out the battery.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 63
All Time: 822
