Lenovo V14-IIL Back Panel Replacement
    1. Lenovo V14-IIL Back Panel Replacement, Back Panel: step 1, image 1 of 2 Lenovo V14-IIL Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
      • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo V14-IIL Back Panel Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
      • You may need to move the tool to different locations to fully release the back cover.
      Ask FixBot
    3. Lenovo V14-IIL Back Panel Replacement: step 3, image 1 of 1
      • Lift away the back panel and set it aside.
      Ask FixBot
Kristen Gismondi
109,527 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 65
All Time: 488
