Lenovo V14-ADA Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
75
All Time:
474
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach you how to replace the fan in the Lenovo V14-ADA.
Failure of the fan in the system will cause the CPU to overheat quickly. This will cause the computer to shut down or display a blue screen.
STOP CODE: CRITICAL_PROCESS_DED
This a good indicator that your CPU has overheated, which is often due to the fan failing. A failing fan could be due to a faulty part or to a fan that needs cleaning.
Parts
Tools
    1. Lenovo V14-ADA Fan Replacement, Back Panel: step 1, image 1 of 1
      • Turn off the laptop.
      • Disconnect the charging cable from the laptop.
      • Failure to unplug the cable could result in electric shock.
      • Flip the laptop upside down.
      Ask FixBot
    2. Lenovo V14-ADA Fan Replacement: step 2, image 1 of 1
      • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
      Ask FixBot
    3. Lenovo V14-ADA Fan Replacement: step 3, image 1 of 2 Lenovo V14-ADA Fan Replacement: step 3, image 2 of 2
      • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
      • Repeat this until the panel pops off.
      Ask FixBot
    1. Lenovo V14-ADA Fan Replacement, Fan: step 4, image 1 of 2 Lenovo V14-ADA Fan Replacement, Fan: step 4, image 2 of 2
      • Use a JIS #0 screwdriver to remove the three 6 mm screws holding the fan in place.
      Ask FixBot
    2. Lenovo V14-ADA Fan Replacement: step 5, image 1 of 1
      • Disconnect the white plug by pulling outwards.
      • Remove the fan from the laptop.
      Ask FixBot
Ryder White
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 75
All Time: 474
