Lenovo V14-ADA Battery Replacement
  1. Lenovo V14-ADA Battery Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
    Ask FixBot
  2. Lenovo V14-ADA Battery Replacement: step 2, image 1 of 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
    Ask FixBot
  3. Lenovo V14-ADA Battery Replacement: step 3, image 1 of 2 Lenovo V14-ADA Battery Replacement: step 3, image 2 of 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
    Ask FixBot
  4. Lenovo V14-ADA Battery Replacement, Battery: step 4, image 1 of 2 Lenovo V14-ADA Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
    Ask FixBot
Samaya Roukoz
268 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 579
