Lenovo Thinkpad x230 Keyboard Replacement
    1. Lenovo Thinkpad x230 Keyboard Replacement, Preparations: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      Ask FixBot
    2. Lenovo Thinkpad x230 Keyboard Replacement, Locate the battery: step 2, image 1 of 1
      • Flip the computer upside down.
      • The red rectangle shows the location of the battery.
      Ask FixBot
    3. Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: step 3, image 1 of 3 Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: step 3, image 2 of 3 Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: step 3, image 3 of 3
      • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
      Ask FixBot
    4. Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: step 4, image 1 of 3 Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: step 4, image 2 of 3 Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: step 4, image 3 of 3
      • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
      Ask FixBot
    1. Lenovo Thinkpad x230 Keyboard Replacement, remove screws: step 5, image 1 of 3 Lenovo Thinkpad x230 Keyboard Replacement, remove screws: step 5, image 2 of 3 Lenovo Thinkpad x230 Keyboard Replacement, remove screws: step 5, image 3 of 3
      • There are 2 screws securing the keyboard. You can identify them by a small keyboard symbol (marked by an orange rectangle in the second picture).
      • Once you have located the two screws, remove them with a small Phillips screwdriver.
      Ask FixBot
    2. Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: step 6, image 1 of 3 Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: step 6, image 2 of 3 Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: step 6, image 3 of 3
      • This step is not required.
      • Gently pull the strip out from the case.
      Ask FixBot
    3. Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: step 7, image 1 of 2 Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: step 7, image 2 of 2
      • Use a a plastic spudger (or a flat screwdriver) to push the keyboard towards the screen. This will pop the bottom of the keyboard out of the casing.
      Ask FixBot
    4. Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: step 8, image 1 of 2 Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: step 8, image 2 of 2
      • Carefully lift the keyboard so that you can access its connector.
      Ask FixBot
    5. Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: step 9, image 1 of 2 Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: step 9, image 2 of 2
      • Carefully unplug the connector by pulling.
      Ask FixBot
    6. Lenovo Thinkpad x230 Keyboard Replacement, done: step 10, image 1 of 1
      • You are done - the keyboard is not connected to the laptop any more and can be replaced.
      Ask FixBot
12 other people completed this guide.
Johannes
1,115 Reputation
3 Guides authored
4 Guide Comments
Very good instructions. Really easy. Difficulty rather easy than moderate. Took me two minutes.
Carsten Mühlberg - Reply Share
How do I reinsert the strip above the keyboard? When I insert the bottom clips first I can’t get the top ones in and vice versa. Also I don’t understand the mechanism of the top clips, why do they have the shape they do?
Daan - Reply Share
Worked perfectly. It was easy enough that I could use a key ring screw driver
Chris Barry - Reply Share
Quisiera saber cómo reparar el teclado ya que está en corte y no me deja encender la laptop
Mario Sánchez Soroa - Reply Share
Past 24 Hours: 18
Past 7 Days: 61
Past 30 Days: 201
All Time: 13,483
