Lenovo Thinkpad Tablet 1838 Touch Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
83
All Time:
1,389
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the touch screen on the Lenovo ThinkPad Tablet 1838.
The touch screen is what allows the users to see images and interact with them with the usage of their fingertips. In the case that these attributes are compromised, such as if the screen is cracked or stopped displaying, replacement of the screen may be needed.
If replacing a glass cracked screen, be cautious of little shards of glass that may be harmful to your body. You can place tape over the screen to make sure that all the pieces of glass are secure.
Before using this guide to aid with the replacement of the screen, make sure that device is unplugged and powered off.
Tools
    1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement, Touch Screen: step 1, image 1 of 1
      • Remove the button with the arrow pointing left.
      • You can do this by putting the spudger underneath the button and pulling up.
      Ask FixBot
    2. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 2, image 1 of 1
      • Remove the two 10mm Phillips #00 screws.
      Ask FixBot
    3. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 3, image 1 of 1
      • Use an opening tool to pry open and disconnect the screen from the rest of the tablet.
      • Be gentle and work from the bottom of the tablet in counterclockwise direction.
      Ask FixBot
    4. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 4, image 1 of 1
      • Open the tablet screen to the left, making sure not to disconnect any of the wires connecting the screen to the tablet.
      Ask FixBot
    5. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 5, image 1 of 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 5, image 2 of 2
      • Disconnect the ribbon connector by pulling up on the white gate.
      • Then just simply pull the wire to the left to disconnect it.
      Ask FixBot
    6. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 6, image 1 of 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 6, image 2 of 2
      • Disconnect the last ribbon connector using your fingernails to grip the ends of the connector and gently pull to the left.
      • There might be some tape over the connector that you will have to remove.
      Ask FixBot
    7. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: step 7, image 1 of 1
      • You have successfully removed the old screen.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 83
All Time: 1,389
