Lenovo Thinkpad Tablet 1838 Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
77
All Time:
803
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Use this guide if either your power or volume buttons have stopped working or if you just want to clean them.
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
    1. Lenovo Thinkpad Tablet 1838 Button Replacement, Button: step 1, image 1 of 1
      • Remove the button on the front of the tablet that has the arrow pointing to the left .
      • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
      Ask FixBot
    2. Lenovo Thinkpad Tablet 1838 Button Replacement: step 2, image 1 of 1
      • Remove the 2 screws found under the button you just removed with a size #00 Philips Head Screwdriver.
      Ask FixBot
    3. Lenovo Thinkpad Tablet 1838 Button Replacement: step 3, image 1 of 1
      • Use a plastic spudger to pry open the screen from the tablet.
      • Work around the perimeter of the tablet going counter-clockwise.
      Ask FixBot
    4. Lenovo Thinkpad Tablet 1838 Button Replacement: step 4, image 1 of 1
      • Open the tablet screen to the left. (Like opening a book) Making sure not to disconnect any of the wires connecting the screen and tablet.
      Ask FixBot
    5. Lenovo Thinkpad Tablet 1838 Button Replacement: step 5, image 1 of 1
      • To peel back the ribbon connector, first gently open the white gates.
      • You can do this with a plastic Spudger or your fingernail.
      Ask FixBot
    6. Lenovo Thinkpad Tablet 1838 Button Replacement: step 6, image 1 of 1
      • Remove the screw that is highlighted.
      • Use a size #00 Philips head screwdriver.
      Ask FixBot
    7. Lenovo Thinkpad Tablet 1838 Button Replacement: step 7, image 1 of 1
      • Remove the blue motherboard the screw was attached to.
      • Make sure to remove it carefully, so you do not accidentally damage the surrounding parts.
      Ask FixBot
    8. Lenovo Thinkpad Tablet 1838 Button Replacement: step 8, image 1 of 3 Lenovo Thinkpad Tablet 1838 Button Replacement: step 8, image 2 of 3 Lenovo Thinkpad Tablet 1838 Button Replacement: step 8, image 3 of 3
      • To remove the buttons, you need to push the little black tabs towards each other with either your fingernails or plastic spudger.
      • While the tabs are pushed in the buttons should pop out.
      Ask FixBot
Dylan Coleman
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 77
All Time: 803
