Lenovo Thinkpad T450s Thermal Paste Replacement
    1. Lenovo Thinkpad T450s Thermal Paste Replacement, Opening the back panel: step 1, image 1 of 3 Lenovo Thinkpad T450s Thermal Paste Replacement, Opening the back panel: step 1, image 2 of 3 Lenovo Thinkpad T450s Thermal Paste Replacement, Opening the back panel: step 1, image 3 of 3
      • Unscrew all screws holding the back panel in place.
      • Remove the battery. There is a screw below the battery as well.
      • Use a prying tool to remove the back panel.
      • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
      Ask FixBot
    2. Lenovo Thinkpad T450s Thermal Paste Replacement, Changing the thermal paste: step 2, image 1 of 3 Lenovo Thinkpad T450s Thermal Paste Replacement, Changing the thermal paste: step 2, image 2 of 3 Lenovo Thinkpad T450s Thermal Paste Replacement, Changing the thermal paste: step 2, image 3 of 3
      • Clean the old thermal paste from both the cooler and the CPU.
      • Use isopropyl alcohol and cotton swabs or paper towel, but be careful not to press too hard on the CPU.
      • It's also recommended to use compressed air to remove any dust in the laptop and the fan.
      • Use only enough thermal paste to cover a portion of the pad. Use a spreader if you have one.
      • The thermal paste will apply evenly after you tighten the heatsink.
      • Place the heatsink back into the unit carefully and tighten the screws in an "X" pattern to ensure even pressure. Don't forget to plug in the fan cable.
      Ask FixBot
    3. Lenovo Thinkpad T450s Thermal Paste Replacement, Other upgrades: step 3, image 1 of 1
      • Once you have the back cover opened, it is a good opportunity to upgrade the SSD and RAM.
      Ask FixBot
Simeon Brankov
10,409 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 36
All Time: 94
