Lenovo Thinkpad T450s Screen Display Replacement
Views: 12K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
120
All Time:
11,651
Comments: 4
4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you are having display issues, you may find that you need to replace the screen. You can utilizes this guide to give you step by step instructions on how to replace the screen on your device.
Parts
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
    1. Lenovo Thinkpad T450s Screen Display Replacement, Screen Display: step 1, image 1 of 1
      • Open the device so that it is laying flat
      • Turn off device before starting
      Ask FixBot
    2. Lenovo Thinkpad T450s Screen Display Replacement: step 2, image 1 of 3 Lenovo Thinkpad T450s Screen Display Replacement: step 2, image 2 of 3 Lenovo Thinkpad T450s Screen Display Replacement: step 2, image 3 of 3
      • Pry the bottom right corner of the screen’s border and gently peel off the adhesive screen cover
      • You will find a sticky adhesive under the screen border. Be gentle when pulling it off and take your time to insure that you do not damage it.
      Ask FixBot
    3. Lenovo Thinkpad T450s Screen Display Replacement: step 3, image 1 of 1
      • Unscrew the screws from each corner of the screen
      Ask FixBot
    4. Lenovo Thinkpad T450s Screen Display Replacement: step 4, image 1 of 1
      • Slowly lean the computer forward so that the screen gently falls into your hand
      Ask FixBot
    5. Lenovo Thinkpad T450s Screen Display Replacement: step 5, image 1 of 3 Lenovo Thinkpad T450s Screen Display Replacement: step 5, image 2 of 3 Lenovo Thinkpad T450s Screen Display Replacement: step 5, image 3 of 3
      • Unplug the cord that connects the screen to the rest of the computer
      • Carefully use a metal prying tool to disconnect the two metal prong ends underneath the tape.
      Ask FixBot
6 other people completed this guide.
4 Guide Comments
there is a step where you remove a simple harness which requires a spudger to de-clip it from the main frame of the laptop, but I gotta say that this walkthrough REALLY was the big difference maker for me in feeling like I could do this job. THANK YOU!!!!!
Geoff Kennedy - Reply Share
Correct you are... it important to point that because you can damage it with too much presure trying to get the screen out. Cause I was like, hold up! My screen didnt just flop out like his after removing the four screws that held the screen in place. Luckily, while applying lite pressure trying to get the screen out, the plastic frame popped apart, and I was like okay! Ole boy didnt mention this. So yeah. Please remove that plastic frame before you remove the screen.
Uno!
Alvin Thomas - Reply Share
Just confirming the missing step: it happens after the unscrewing. Thanks.
Ben Moran - Reply Share
There really needs to be a note covering removal of BOTH the external battery - and ALSO the internal battery (which means removing the back of the case (simple retained screws) and unplugging the battery inside.
These steps are vital as the battery provides a constant live power rail to the screen even when turned off. Without disabling both batteries there is a risk that, when detaching or attaching the new screen to the cable, a short can happen which can blow a fuse on the motherboard - breaking the backlight.
Andrew Gregg - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 120
All Time: 11,651
