Lenovo Thinkpad T450s Keyboard Replacement
Views: 9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
164
All Time:
9,015
Comments: 7
6 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you are encountering issues with your keyboard, there is a possibility that you might have to replace it. You can utilize this guide to receive step by step instruction to complete this task manually by yourself.
Parts
Tools
    1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove the battery by pulling on the two sliding buttons next to the battery.
      Ask FixBot
    2. Lenovo Thinkpad T450s Keyboard Replacement: step 2, image 1 of 2 Lenovo Thinkpad T450s Keyboard Replacement: step 2, image 2 of 2
      • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo Thinkpad T450s Keyboard Replacement: step 3, image 1 of 1
      • Remove the two rubber stoppers from where the battery previously was.
      Ask FixBot
    4. Lenovo Thinkpad T450s Keyboard Replacement: step 4, image 1 of 2 Lenovo Thinkpad T450s Keyboard Replacement: step 4, image 2 of 2
      • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
      • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
      • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
      Ask FixBot
    5. Lenovo Thinkpad T450s Keyboard Replacement: step 5, image 1 of 1
      • Lift the keyboard and flip over exposing the connection to the motherboard.
      Ask FixBot
    6. Lenovo Thinkpad T450s Keyboard Replacement: step 6, image 1 of 1
      • Remove the plastic covering and detach touch point and keyboard cable.
      Ask FixBot
5 other people completed this guide.
Nathan Morgan
499 Reputation
2 Guides authored
IUPUI, Team S2-G5, Stella Fall 2019 Member of IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Members
24 Guides authored
1 Guide Comment
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 164
All Time: 9,015
