Lenovo Thinkpad T450s Bottom Panel Removal
    1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: step 1, image 1 of 2 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: step 1, image 2 of 2
      • Turn off device before starting
      • Flip the laptop upside down so you have access to the battery.
      Ask FixBot
    2. Lenovo Thinkpad T450s Bottom Panel Removal: step 2, image 1 of 1
      • Slide lock button 1 to the unlock position and gently slide away from your body.
      Ask FixBot
    3. Lenovo Thinkpad T450s Bottom Panel Removal: step 3, image 1 of 2 Lenovo Thinkpad T450s Bottom Panel Removal: step 3, image 2 of 2
      • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
      Ask FixBot
    1. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: step 4, image 1 of 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: step 4, image 2 of 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: step 4, image 3 of 3
      • Flip the device over and lay it down with the underside facing upwards.
      • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
      Ask FixBot
    2. Lenovo Thinkpad T450s Bottom Panel Removal: step 5, image 1 of 2 Lenovo Thinkpad T450s Bottom Panel Removal: step 5, image 2 of 2
      • Pry the bottom from the computer until it pops out.
      • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 4,501
