Lenovo Thinkpad T450 SSD Replacement
Views: 9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
46
Past 30 Days:
169
All Time:
8,959
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The solid-state drive (or SSD) is a storage device used to store data. SSDs are much faster than the traditional hard-disc drives (HDD) due to their physical nature. Unlike the standard HDD, an SSD does not have a physical spinning disc in the component. Current estimates show that SSDs may reach a lifespan of 10 years, but the average lifespan of a SSD is shorter.
If your Lenovo ThinkPad T450 laptop is not properly loading files or is slow to load, it may be time to replace the SSD. Follow these instructions to replace the SSD in your device.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo Thinkpad T450 SSD Replacement, External Battery: step 1, image 1 of 3 Lenovo Thinkpad T450 SSD Replacement, External Battery: step 1, image 2 of 3 Lenovo Thinkpad T450 SSD Replacement, External Battery: step 1, image 3 of 3
      • Using your hands, slide the two locking tabs away from each other to release the battery.
      • Slide the battery up and out of the device.
      Ask FixBot
    1. Lenovo Thinkpad T450 SSD Replacement, Back Cover: step 2, image 1 of 1
      • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
      • These screws are not removable and will remain in the back cover.
      • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
      Ask FixBot
    2. Lenovo Thinkpad T450 SSD Replacement: step 3, image 1 of 3 Lenovo Thinkpad T450 SSD Replacement: step 3, image 2 of 3 Lenovo Thinkpad T450 SSD Replacement: step 3, image 3 of 3
      • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
      • Remove the back cover from the device.
      Ask FixBot
    1. Lenovo Thinkpad T450 SSD Replacement, SSD: step 4, image 1 of 1
      • Using the JIS #00 screwdriver, remove the single 2.8 mm screw securing the SSD to the device.
      Ask FixBot
    2. Lenovo Thinkpad T450 SSD Replacement: step 5, image 1 of 2 Lenovo Thinkpad T450 SSD Replacement: step 5, image 2 of 2
      • Lift the SSD up and to the left and remove it from the device.
      Ask FixBot
2 other people completed this guide.
Justin Ogihara
31,632 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 169
All Time: 8,959
