Lenovo Thinkpad T430 Keyboard Replacement
Views: 2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
38
Past 30 Days:
174
All Time:
1,958
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The keyboard is a key component to any computer. It is the place where you mix the electronics and the inputs from typing. It is the place where you tell the computer what to do. This guide will show you how to remove the Lenovo Thinkpad T430 keyboard to be able to replace it.
Tools
    1. Lenovo Thinkpad T430 Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad T430 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Place the laptop so that the bottom is facing up.
      • Slide the battery unlock lever to the right.
      • Gently pull the battery outwards from the body of the device.
      Ask FixBot
    1. Lenovo Thinkpad T430 Keyboard Replacement, Keyboard: step 2, image 1 of 2 Lenovo Thinkpad T430 Keyboard Replacement, Keyboard: step 2, image 2 of 2
      • Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
      • Remove the back panel.
      Ask FixBot
    2. Lenovo Thinkpad T430 Keyboard Replacement: step 3, image 1 of 1
      • Remove the two screws in the middle panel using a Phillips #000 screwdriver.
      Ask FixBot
    3. Lenovo Thinkpad T430 Keyboard Replacement: step 4, image 1 of 2 Lenovo Thinkpad T430 Keyboard Replacement: step 4, image 2 of 2
      • Flip the laptop over and open the lid.
      • Push the keyboard forward from the space bar while applying pressure to lift up the keyboard.
      • Carefully unplug and disconnect the ribbon cable.
      • Pulling too hard on the ribbon cable may cause damage to the device. Make sure to disconnect the ribbon cable before completely removing the keyboard.
      Ask FixBot
Jacob Ferreira
97 Reputation
1 Guide authored
UMass Dartmouth, Team 1-5, Konn Fall 2024 Member of UMass Dartmouth, Team 1-5, Konn Fall 2024
UMASSD-KONN-F24S1G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 174
All Time: 1,958
