Lenovo Thinkpad Helix Motherboard Replacement
    1. Lenovo Thinkpad Helix  Motherboard Replacement, Screen: step 1, image 1 of 1
      • Using a plastic opening tool or opening pick, gently pry the screen off.
      • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
      • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
      • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
      Ask FixBot
    2. Lenovo Thinkpad Helix  Motherboard Replacement: step 2, image 1 of 3 Lenovo Thinkpad Helix  Motherboard Replacement: step 2, image 2 of 3 Lenovo Thinkpad Helix  Motherboard Replacement: step 2, image 3 of 3
      • Lift the screen up slowly.
      • Once separated, you can not fully take it off due to some cable connections.
      • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
      Ask FixBot
    3. Lenovo Thinkpad Helix  Motherboard Replacement: step 3, image 1 of 1
      • Once the cables are disconnected, remove the screen.
      Ask FixBot
    1. Lenovo Thinkpad Helix  Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Remove the seven, 3mm, Phillips #00 screws attaching motherboard to the back cover.
      Ask FixBot
    2. Lenovo Thinkpad Helix  Motherboard Replacement: step 5, image 1 of 1
      • Remove the white clips, then gently pull out both the motherboard and fan.
      Ask FixBot
Aron Ndikumana
115 Reputation
1 Guide authored
Gateway, Team S1-G6, Saknee Fall 2019 Member of Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 84
All Time: 1,700
