Lenovo Thinkpad Edge E545 Back Panel Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
90
All Time:
969
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The purpose of this guide is to teach you to remove the back panel of this laptop for replacement or other necessary changes. To place the panel back on the laptop, reverse the order of the guide.
Tools
    1. Lenovo Thinkpad Edge E545 Back Panel Replacement, Battery: step 1, image 1 of 1
      • First, flip the laptop over as shown in the photo.
      • Make sure device is fully powered down before removing battery.
      Ask FixBot
    2. Lenovo Thinkpad Edge E545 Back Panel Replacement: step 2, image 1 of 1
      • Below the battery are two small tabs. These function as a lock for the battery.
      • Push the tabs towards each other to release the battery.
      Ask FixBot
    3. Lenovo Thinkpad Edge E545 Back Panel Replacement: step 3, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
    1. Lenovo Thinkpad Edge E545 Back Panel Replacement, Back Panel: step 4, image 1 of 1
      • Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
      • It is recommend that you fully remove the screws and place them in a secure location.
      • Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
      Ask FixBot
    2. Lenovo Thinkpad Edge E545 Back Panel Replacement: step 5, image 1 of 2 Lenovo Thinkpad Edge E545 Back Panel Replacement: step 5, image 2 of 2
      • Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
      • Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
      Ask FixBot
    3. Lenovo Thinkpad Edge E545 Back Panel Replacement: step 6, image 1 of 1
      • Remove the back panel.
      • The back of the laptop will be exposed once the panel is removed.
      • Many of these small components are easily damaged--do not touch anything unless instructed to.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 90
All Time: 969
