Lenovo Thinkpad Edge E40 RAM Replacement
    1. Lenovo Thinkpad Edge E40 RAM Replacement, Battery: step 1, image 1 of 1
      • Flip your laptop over.
      • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
      Ask FixBot
    2. Lenovo Thinkpad Edge E40 RAM Replacement, Battery: step 2, image 1 of 1
      • Pull the locking tab on the battery towards the unlock position.
      • Pull the battery out of the socket.
      Ask FixBot
    1. Lenovo Thinkpad Edge E40 RAM Replacement, Bottom Cover: step 3, image 1 of 1
      • Loosen the following five screws:
      • 5 Phillips #0 screws
      • 1 recessed Phillips #0 screw
      • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
      Ask FixBot
    2. Lenovo Thinkpad Edge E40 RAM Replacement, Bottom Cover: step 4, image 1 of 1
      • Pull up on the front cover from the left and right sides.
      • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
      Ask FixBot
    1. Lenovo Thinkpad Edge E40 RAM Replacement, RAM: step 5, image 1 of 2 Lenovo Thinkpad Edge E40 RAM Replacement, RAM: step 5, image 2 of 2
      • Pull the two tabs on the sides of the RAM.
      • Repeat on the second stick.
      • Do not touch the gold contacts on the RAM, because that could easily damage the RAM.
      Ask FixBot
DistroHopper39B
414 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 67
All Time: 465
