Lenovo Thinkpad E540 WiFi Card Replacement
    1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad E540 WiFi Card Replacement, Battery: step 1, image 2 of 2
      • Push the battery release switches away from each other.
      Ask FixBot
    2. Lenovo Thinkpad E540 WiFi Card Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: step 3, image 1 of 1
      • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
      Ask FixBot
    2. Lenovo Thinkpad E540 WiFi Card Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to remove panel.
      Ask FixBot
    3. Lenovo Thinkpad E540 WiFi Card Replacement: step 5, image 1 of 2 Lenovo Thinkpad E540 WiFi Card Replacement: step 5, image 2 of 2
      • Disconnect the two antenna cables from the wifi card.
      • Remove the single 1mm Phillips #0 screw from the wifi card.
      Ask FixBot
    4. Lenovo Thinkpad E540 WiFi Card Replacement: step 6, image 1 of 1
      • Remove the wifi card by sliding it out.
      Ask FixBot
3 other people completed this guide.
Timothy Sumner
1,052 Reputation
8 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2018 Member of USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Members
96 Guides authored
2 Guide Comments
Pictures show battery is still connected to laptop.
Monte Christo - Reply Share
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 3,801
