Lenovo Thinkpad E540 Keyboard Replacement
Views: 12K
View statistics:
Past 24 Hours:
Past 7 Days:
31
Past 30 Days:
142
All Time:
12,267
Comments: 4
4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A guide on how to replace the individual keys on a Lenovo ThinkPad E540 laptop.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad E540 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Push the battery release switches away from each other.
      Ask FixBot
    2. Lenovo Thinkpad E540 Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Lenovo Thinkpad E540 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Push the keyboard forward towards the display to create a gap above the trackpad.
      Ask FixBot
    2. Lenovo Thinkpad E540 Keyboard Replacement: step 4, image 1 of 1
      • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
      Ask FixBot
    3. Lenovo Thinkpad E540 Keyboard Replacement: step 5, image 1 of 1
      • Tilt the keyboard forward from the top and lift gently.
      • Dont pull too far because there is a cable attached to the back.
      Ask FixBot
    4. Lenovo Thinkpad E540 Keyboard Replacement: step 6, image 1 of 2 Lenovo Thinkpad E540 Keyboard Replacement: step 6, image 2 of 2
      • Use a spudger to lift the black latch on the ZIF connectors.
      • Remove the blue and purple ribbon cables from the ZIF connectors.
      Ask FixBot
2 other people completed this guide.
Timothy Sumner
1,058 Reputation
8 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2018 Member of USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Members
96 Guides authored
4 Guide Comments
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - Reply Share
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - Reply Share
With my edge 540 (submodel unknown) I was able to reach the screws by pushing the screw driver under the plastic grid. It did however slightly scuff up my F key
Dick van Zalinge - Reply Share
You forgot the latch underneath the main battery.
Moose Technologies - Reply Share
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 142
All Time: 12,267
