Lenovo Thinkpad E540 Hard Drive Replacement
    1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad E540 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Push the battery release switches away from each other.
      Ask FixBot
    2. Lenovo Thinkpad E540 Hard Drive Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Lenovo Thinkpad E540 Hard Drive Replacement, Disassembly of the Back Panel: step 3, image 1 of 1
      • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
      Ask FixBot
    2. Lenovo Thinkpad E540 Hard Drive Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to pry off the bottom panel.
      Ask FixBot
    1. Lenovo Thinkpad E540 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Remove the four 1.2mm Phillips #0 screws from the hard drive.
      Ask FixBot
    2. Lenovo Thinkpad E540 Hard Drive Replacement: step 6, image 1 of 1
      • Pull up on the hard drive to allow for removal.
      Ask FixBot
    3. Lenovo Thinkpad E540 Hard Drive Replacement: step 7, image 1 of 1
      • Disconnect the hard drive and pull out to remove.
      Ask FixBot
4 other people completed this guide.
Timothy Sumner
1,052 Reputation
8 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2018 Member of USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Members
96 Guides authored
1 Guide Comment
Thanks for this invaluable and easy guide.
Is it possible to replace the hdd with an ssd for this model? If so, which ssd would fit this laptop’s hdd socket?
Many thanks in advance.
SKP - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 56
All Time: 6,462
