Lenovo Thinkpad E540 Fan Replacement
  1. Lenovo Thinkpad E540 Fan Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad E540 Fan Replacement, Battery: step 1, image 2 of 2
    • Push the battery release switches away from each other.
    Ask FixBot
  2. Lenovo Thinkpad E540 Fan Replacement: step 2, image 1 of 1
    • Remove the battery.
    Ask FixBot
  3. Lenovo Thinkpad E540 Fan Replacement, Disassembly of the Back Panel: step 3, image 1 of 1
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
    Ask FixBot
  4. Lenovo Thinkpad E540 Fan Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry off the bottom panel.
    Ask FixBot
  5. Lenovo Thinkpad E540 Fan Replacement, Fan: step 5, image 1 of 1
    • Heatsink and fan are connected. You have to remove both at the same time.
    • The heatsink and fan are found on the right side.
    Ask FixBot
  6. Lenovo Thinkpad E540 Fan Replacement: step 6, image 1 of 1
    • Remove the two 1mm Phillips #0 screws from the fan.
    • Unscrew the four 2mm Phillips s#0 screws from the heatsink.
    • The screws on the heatsink will stay attached to it.
    Ask FixBot
  7. Lenovo Thinkpad E540 Fan Replacement: step 7, image 1 of 1
    • To remove the heatsink and fan, pull the fan upwards and towards the center.
    Ask FixBot
2 other people completed this guide.
Timothy Sumner
1,052 Reputation
8 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2018 Member of USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 56
All Time: 3,163
