Lenovo Thinkpad E540 Display Screen Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
96
All Time:
5,922
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
A guide on how to replace the scree on a Lenovo ThinkPad E540 laptop.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Lenovo Thinkpad E540 Display Screen Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad E540 Display Screen Replacement, Battery: step 1, image 2 of 2
      • Push the battery release switches away from each other.
      Ask FixBot
    2. Lenovo Thinkpad E540 Display Screen Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Lenovo Thinkpad E540 Display Screen Replacement, Display Screen: step 3, image 1 of 1
      • Remove the two stickers at the bottom corners for the screen to reveal the screws.
      • Remove the two 1mm Phillips #00 screws from underneath the stickers.
      Ask FixBot
    2. Lenovo Thinkpad E540 Display Screen Replacement: step 4, image 1 of 1
      • Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
      Ask FixBot
    3. Lenovo Thinkpad E540 Display Screen Replacement: step 5, image 1 of 1
      • Remove the six 1.3mm Phillips #00 screws from around the display.
      Ask FixBot
    4. Lenovo Thinkpad E540 Display Screen Replacement: step 6, image 1 of 1
      • Remove the plastic covering and six 1.3mm Phillips #00 screws from both sides of the display.
      Ask FixBot
    5. Lenovo Thinkpad E540 Display Screen Replacement: step 7, image 1 of 3 Lenovo Thinkpad E540 Display Screen Replacement: step 7, image 2 of 3 Lenovo Thinkpad E540 Display Screen Replacement: step 7, image 3 of 3
      • Remove the orange tape covering the display connector.
      • Disconnect the display's ribbon cable by lifting up the latch and flipping it over 180 degrees.
      Ask FixBot
Timothy Sumner
1,058 Reputation
8 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2018 Member of USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 96
All Time: 5,922
