Lenovo ThinkPad x120e RAM Replacement
    1. Lenovo ThinkPad x120e RAM Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad x120e RAM Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop upside down and locate the battery latches under the battery.
      • Place your thumbs on both latches and push the latch inwards.
      • With your thumbs still on the latches, slide the battery out of the laptop.
      • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
      Ask FixBot
    1. Lenovo ThinkPad x120e RAM Replacement, Back Cover: step 2, image 1 of 3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: step 2, image 2 of 3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: step 2, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
      • Remove the backplate carefully, making sure not to bend the cover.
      Ask FixBot
    1. Lenovo ThinkPad x120e RAM Replacement, RAM: step 3, image 1 of 3 Lenovo ThinkPad x120e RAM Replacement, RAM: step 3, image 2 of 3 Lenovo ThinkPad x120e RAM Replacement, RAM: step 3, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Push the two mounting clips on either side of the RAM away from each other.
      • While doing this step, wear an anti-static wrist strap. This will prevent you from generating static that could damage the RAM module.
      Ask FixBot
    2. Lenovo ThinkPad x120e RAM Replacement: step 4, image 1 of 2 Lenovo ThinkPad x120e RAM Replacement: step 4, image 2 of 2
      • The RAM should now be lifting up at an angle.
      • Slide the RAM stick out in the direction the angle is facing.
      • While installing the new RAM stick, push the stick down at an angle and make sure you secure it with the small clips at both sides.
      Ask FixBot
Jacob Fronzaglia
787 Reputation
6 Guides authored
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 74
All Time: 876
