Lenovo ThinkPad x120e LCD Screen Replacement
    1. Lenovo ThinkPad x120e LCD Screen Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad x120e LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop upside down and locate the battery latches under the battery.
      • Place your thumbs on both latches and push the latch inwards.
      • With your thumbs still on the latches, slide the battery out of the laptop.
      • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
      Ask FixBot
    1. Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: step 2, image 1 of 3 Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: step 2, image 2 of 3 Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: step 2, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
      • Remove the backplate carefully, making sure not to bend the cover.
      Ask FixBot
    1. Lenovo ThinkPad x120e LCD Screen Replacement, Keyboard: step 3, image 1 of 2 Lenovo ThinkPad x120e LCD Screen Replacement, Keyboard: step 3, image 2 of 2
      Ask FixBot
    2. Lenovo ThinkPad x120e LCD Screen Replacement: step 4, image 1 of 3 Lenovo ThinkPad x120e LCD Screen Replacement: step 4, image 2 of 3 Lenovo ThinkPad x120e LCD Screen Replacement: step 4, image 3 of 3
      • Flip the laptop back over, showing the keyboard.
      • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
      • You should see two ribbon wires located beneath the keyboard once you are done.
      Ask FixBot
    3. Lenovo ThinkPad x120e LCD Screen Replacement: step 5, image 1 of 2 Lenovo ThinkPad x120e LCD Screen Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Pull on the black tabs above both ribbon wires using tweezers upwards.
      • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
      • Remove both ribbon wires.
      • Remove the keyboard from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad x120e LCD Screen Replacement, LCD Screen: step 6, image 1 of 2 Lenovo ThinkPad x120e LCD Screen Replacement, LCD Screen: step 6, image 2 of 2
      • Remove the screw covers that are located on both sides of the display using a spudger.
      • Start from the corners of the screw covers to remove it more easily.
      Ask FixBot
    2. Lenovo ThinkPad x120e LCD Screen Replacement: step 7, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the two 4 mm screws.
      Ask FixBot
    3. Lenovo ThinkPad x120e LCD Screen Replacement: step 8, image 1 of 1
      • Pry open the frame of the laptop screen using a spudger.
      • Do not try to pry it open from the inside edge of the frame. You may accidentaly damage the screen.
      Ask FixBot
    4. Lenovo ThinkPad x120e LCD Screen Replacement: step 9, image 1 of 1
      • Using the Phillips #1 screwdriver, remove six screws securing the screen to the device.
      Ask FixBot
    5. Lenovo ThinkPad x120e LCD Screen Replacement: step 10, image 1 of 2 Lenovo ThinkPad x120e LCD Screen Replacement: step 10, image 2 of 2
      • Lift up the screen from the top. You should now notice the metal frame.
      • Using the same Phillips #1 screwdriver, remove four screws, two on each edge of the metal frame.
      • The second picture is rotated 90 degrees.
      Ask FixBot
    6. Lenovo ThinkPad x120e LCD Screen Replacement: step 11, image 1 of 1
      • Remove the connector on top of the webcam by simply pulling it out.
      Ask FixBot
    7. Lenovo ThinkPad x120e LCD Screen Replacement: step 12, image 1 of 2 Lenovo ThinkPad x120e LCD Screen Replacement: step 12, image 2 of 2
      • Flip the screen over.
      • Peel the black tape first, then peel the gray tape down to the base of the screen.
      Ask FixBot
    8. Lenovo ThinkPad x120e LCD Screen Replacement: step 13, image 1 of 1
      • At the base of the screen, there is a transparent tape holding a connector. Peel the tape off.
      Ask FixBot
    9. Lenovo ThinkPad x120e LCD Screen Replacement: step 14, image 1 of 1
      • Remove the connector underneath where the tape was using a spudger tool.
      • Pull out the connector.
      • Make sure to not damage any of the wires.
      Ask FixBot
    10. Lenovo ThinkPad x120e LCD Screen Replacement: step 15, image 1 of 1
      • Remove the gray tape fully.
      • Flip over the device, and remove the LCD screen fully.
      Ask FixBot
Jacob Fronzaglia
787 Reputation
6 Guides authored
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 36
All Time: 629
