Lenovo ThinkPad x120e Keyboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
76
All Time:
947
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Before reading this guide on how to replace the keyboard for the Lenovo ThinkPad x120e, check the “Keyboard Not Responding” section on the device’s troubleshooting page to see if your issue can be fixed without replacement: Lenovo ThinkPad x120e Troubleshooting - iFixit
Reminder: make sure you turn off your laptop and remove any attached power cables before beginning..
Tools
    1. Lenovo ThinkPad x120e Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad x120e Keyboard Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop upside down and locate the battery latches under the battery.
      • Place your thumbs on both latches and push the latch inwards.
      • With your thumbs still on the latches, slide the battery out of the laptop.
      • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
      Ask FixBot
    1. Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: step 2, image 1 of 3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: step 2, image 2 of 3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: step 2, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
      • Remove the backplate carefully, making sure not to bend the cover.
      Ask FixBot
    1. Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: step 3, image 1 of 2 Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: step 3, image 2 of 2
      Ask FixBot
    2. Lenovo ThinkPad x120e Keyboard Replacement: step 4, image 1 of 3 Lenovo ThinkPad x120e Keyboard Replacement: step 4, image 2 of 3 Lenovo ThinkPad x120e Keyboard Replacement: step 4, image 3 of 3
      • Flip the laptop back over, showing the keyboard.
      • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
      • You should see two ribbon wires located beneath the keyboard once you are done.
      Ask FixBot
    3. Lenovo ThinkPad x120e Keyboard Replacement: step 5, image 1 of 2 Lenovo ThinkPad x120e Keyboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Pull on the black tabs above both ribbon wires using tweezers upwards.
      • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
      • Remove both ribbon wires.
      • Remove the keyboard from the laptop.
      Ask FixBot
Jacob Fronzaglia
787 Reputation
6 Guides authored
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 76
All Time: 947
