Lenovo ThinkPad Yoga RAM Replacement
    1. Lenovo ThinkPad Yoga RAM Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement, Battery: step 1, image 3 of 3
      • Flip the laptop over so the bottom is facing you.
      • Remove the ten screws using a Phillips #1 screwdriver.
      • Using the plastic opening tool, pry the bottom cover off the laptop.
      Ask FixBot
    2. Lenovo ThinkPad Yoga RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 2, image 3 of 3
      • Remove two screws from the battery using a Phillips #1 screwdriver.
      • Disconnect the battery connector from the motherboard.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad Yoga RAM Replacement, RAM: step 3, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement, RAM: step 3, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement, RAM: step 3, image 3 of 3
      • Remove nine screws from the motherboard with a Phillips #1 screwdriver.
      • Remove all ribbon cables attached to the motherboard.
      • Lift the motherboard out of the device.
      Ask FixBot
    2. Lenovo ThinkPad Yoga RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 4, image 3 of 3
      • Desolder the RAM to replace it.
      • You may also opt to replace the entire motherboard if soldering is not an option.
      Ask FixBot
Michael Nessralla
171 Reputation
2 Guides authored
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Member of UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 124
All Time: 3,872
