Lenovo ThinkPad Yoga Keyboard Replacement
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: step 1, image 3 of 3
      • Flip the laptop over so the bottom is facing you.
      • Remove the ten screws using a Phillips #1 screwdriver.
      • Using the plastic opening tool, pry the bottom cover off the laptop.
      Ask FixBot
    2. Lenovo ThinkPad Yoga Keyboard Replacement: step 2, image 1 of 3 Lenovo ThinkPad Yoga Keyboard Replacement: step 2, image 2 of 3 Lenovo ThinkPad Yoga Keyboard Replacement: step 2, image 3 of 3
      • Remove two screws from the battery using a Phillips #1 screwdriver.
      • Disconnect the battery connector from the motherboard.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: step 3, image 1 of 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: step 3, image 2 of 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: step 3, image 3 of 3
      • Disconnect connectors. Use fingers to pinch and pull the connector out.
      Ask FixBot
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: step 4, image 1 of 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: step 4, image 2 of 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: step 4, image 3 of 3
      • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
      • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
      • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
      • Remove the fan from the motherboard.
      Ask FixBot
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad Yoga Keyboard Replacement: step 6, image 1 of 1
      • Use a spudger to pry open the keyboard panel.
      • Continue to pry until the panel is loose enough to take off.
      Ask FixBot
    3. Lenovo ThinkPad Yoga Keyboard Replacement: step 7, image 1 of 1
      • Remove the keyboard from the laptop.
      Ask FixBot
2 other people completed this guide.
Felicia McCarey
299 Reputation
2 Guides authored
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Member of UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 178
All Time: 11,879
