Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
    1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: step 1, image 1 of 1
      • Device needs to be powered off and unplugged.
      • Remove the stylus from the device and set it aside.
      Ask FixBot
    2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 2, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 2, image 2 of 2
      • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
      • The screws will remain attached to the back cover.
      Ask FixBot
    3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 3, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 3, image 2 of 2
      • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
      • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
      Ask FixBot
    4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 4, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 4, image 2 of 2
      • Gently remove the cover by placing your fingers around the edges.
      Ask FixBot
    5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 5, image 1 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 5, image 2 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 5, image 3 of 3
      • With your fingers, fold back the plastic cover highlighted.
      • Using two fingers, gently remove the battery connectors.
      Ask FixBot
    6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 6, image 1 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 6, image 2 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 6, image 3 of 3
      • Using the Phillips #00 screwdriver, remove the two 4mm screws.
      • Remove the battery.
      • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
      Ask FixBot
    1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: step 7, image 1 of 1
      • Identify the fingerprint reader on the left side of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
      Ask FixBot
    3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 9, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 9, image 2 of 2
      • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
      • Remove the metal cover.
      Ask FixBot
    4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 10, image 1 of 1
      • Using tweezers, remove the fingerprint reader from the inset.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 877
