Lenovo ThinkPad X390 SSD Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
159
All Time:
6,906
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo ThinkPad X390 SSD Replacement, SSD: step 1, image 1 of 1
      • Shut down and unplug the laptop before proceeding.
      • Use a Phillips #0 screwdriver to remove the five 2.7 mm screws on the base cover.
      Ask FixBot
    2. Lenovo ThinkPad X390 SSD Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool between the base cover and the chassis.
      • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
      • Lift the base cover up and off.
      Ask FixBot
    3. Lenovo ThinkPad X390 SSD Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
      Ask FixBot
    4. Lenovo ThinkPad X390 SSD Replacement: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
      Ask FixBot
    5. Lenovo ThinkPad X390 SSD Replacement: step 5, image 1 of 1
      • Using your hands, remove the battery from the laptop.
      • Lift the battery up and out of its housing.
      Ask FixBot
    6. Lenovo ThinkPad X390 SSD Replacement: step 6, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the SSD to the motherboard.
      Ask FixBot
    7. Lenovo ThinkPad X390 SSD Replacement: step 7, image 1 of 1
      • Grip the SSD, and gently pull it directly out of its port.
      Ask FixBot
1 Guide Comment
I have been building computers for 15+ years, i didn't go to a fancy college but even I know this tutorial is for replacing the SSD or M.2 to be specific for a X390 laptop. this is not the ram module
Patrick Timmel - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 159
All Time: 6,906
